Well, I had a 3-V blank all profiled out. Still had surface scale, but I did not really think about it prior to profiling the blade. Mounted up the wheel, and ran the blank on the bottom side. I rounded over the edges a little (lesson learned), but not a big deal. But after I got the layer of scale off, I noticed some pretty deep pits. More time on the wheel resulted in more rolled edges, but little improvement in the way of pitting. In a stroke of brilliance, I took the magnetic base of my indicator holder, popped the blade on, mounted up the platen and went to work on getting the pitting out.
I accomplished nothing. THe front side of the platen has been grooved from grinding, and when I applied the blank, it chattered and left some very odd circular indentations in the blank. I flipped the plate over to the virgin side, and tried to remove the pitting and the new indentations. Apparently I applied pressure unevenly, and put a nice tapered flat on one side, and failed to touch the other. The blank now resides in the scrap bucket. And to add insult, the brand new 80g belt is smoked.
I know I can get precision ground stock, but it is pricey (and I understand why). Is there a better way to deal with scale without tearing up belts? Nothing can be done with pitting, it simply has to be ground out, and I will be sure to do it prior to profiling, and use patience. I may go with PG stock in the future to avoid this, but I have many feet of D-2, 154CM, and a significantly shorter piece of 3V.
