Deals for 3/31--Pix Get CAK and more great buys
Yangdu
Moderator
HI WAJASKI SWORD BY DIL BHADUR KAMI
Overall length --26''
Weight -- 26 oz
Spine thickness -- 1/4''
Brass guard and buttcap
Stunning chandan wood handle
Brown leather scabbard with brass tip
Outstanding work by young talented Kami Dil
Add one more to your collection at 245.00 *SOLD*
CHIRUWA ANG KHOLA BY NEW KAMI GET BHADUR
Overall length -- 18''
Weight --39''
Spine thickness --1/2''
Satisal wood handle
Standard leather scabbard
Changa kami special deal at $145 YBB *SOLD*
CHEROKEE ROSE BY MASTER KAMI BURA
Overall lentgth -- 20.5''
Weight -- 26 oz
Sisau wood handle
Brown leather scabbard with white metal tip
Add one more Rose to your collection at $150 YBB *SOLD*
Email to get any or all
Gentleman holding the Wajaski Sword is my friend Randy from Reno
On a side note, I'd like to mention how I love how you pose your blades. That's half the reason I love opening up these threads.
Daniel
Some observations about new kami Get's work (after an opportunity to examine it):
Overall, nice! Not the grand master Bura is in terms of fit and finish, but nothing to complain about. A little more visible laha fill in the gaps, but nothing at all bad.
Very nice woodwork. Very pretty, as you see above.
Heat treatment seemed excellent. No noticeable deformities at all after energetic hard use on hard woods.
Note the prominent ring in the middle of the handle. Where this falls into the right location (which it did in the one I checked out), it really locks the handle into the hand nicely. It really shows a good grasp (pun half intended) of hand ergonomics. The ring in the middle of a khukuri handle seems intended to correspond to the space between the middle and ring fingers, and (a little less obviously, due to the fact that these bones are covered with flesh), the space between the 3rd and 4th metacarpals of the user's hand. (These are the bones in the hand that connect directly to the middle and ring fingers, respectively). When you wrap your hand around the handle, it basically puts a circle of bone directly in front of, and another circle of bone directly behind, the ring--making for a good hold, provided the ring lines up correctly with the user's bone structure. So far, the Get Bhadur Bishwakarma rings I've seen seem to be fairly prominent. I guess this could make it a little uncomfortable if the ring fell into the wrong place in the hand, but if the placement is right, it's a good thing indeed.
The Get chiruwa ang khola (CAK) I handled had an interesting shape and taper. The length was a little shorter than the typical 16.5 inches; the weight was robust, the spine retained much of its half-inch thickness for much of the blade, then tapered a little less gradually than some. Not at all bad; just saying that this will be even more robust as a substitute crowbar than some. No amount of leaning on the knife after it was chopped into a log gave any sign of bending, waving of edge, or any other problem.
Most interesting feature--maybe accidental, but something that might be good to repeat on purpose--is that the "back valley" or indentation at the spine distal to the curve was not a simple thinning of the spine; rather, the metal at the very spine actually thickened a little from its narrowest point, which means you could actually grasp the blade with your hand over the spine and your fingers in the "back valley", and keep a decent grip. This will make it easier to choke way up on the blade, holding it by the spine distal to the curve, and use the blade for fine work. You get a similar phenomenon with a "Gelbu special" or Udhaipur model, I think they're called--the fullers give you something to grip if you hold the blade instead of the handle.
I believe H.I. has itself another good kami. I'll be interested to hear everybody else's observations.
Where are these pictures taken? Forests and hills, evetything seems so beutiful. = )
Nice insights on the Get CAK J.D. Makes me want to get one of his bigger ones. I like the 20" versions I have seen. :thumbup:
Email sent on Wajaski (I could use another Wakazachi).
(Everyone needs more than one hole in the head.)
Hope I'm in time.
Regards,
Bill (AOE4)
Go Bill! I'll live vicariously through you until another batch of dough hits the wallet.
The ridge you see in the background is the Sierra crest just west of Reno. These pictures were taken about half way up the Hunter Lake Road. An interesting side note; if we had shot a picture to the north you would have seen a blacken forest just 25 yards away, just on the other side of the road. Be careful with matches.
Bon Manchee.
Oh boy.
OK, pulled the trigger on the Cherokee Rose. . .
Of course, now that I'm, getting a knife that's bigger than my 20" CAK, I'll have to start carrying my 25"CAK (because it's bad form to have your knife bigger than your kuk).
:D
