Wall of text warning.
First of all, I want to thank the person who told me to push harder and use longer stroke. It has cut (ha, no pun intended) my sharpening time down A LOT.
Long story, read below for the problem.
So I have started using sharpie on my bevels as I freehand. It has super improved my technique. I was very happy with the bevels and deburr on the coarse side of my cheap alum oxide stone. On to the fine side of the stone. It cut faster than expected but, then again, the bevels very very flat by my freehanding standards. Got to the apex and generated a burr. Flipped the burr it a few times while I removed the coarser scratches. My problems started when I began deburring. Again, I thought the bevels were flat by my standards. When I began reducing the pressure, I discovered I was not removing the sharpie all the way down to the apex. No problem. I would just keep making passes at reduced pressure until I removed all of the sharpie.
The problem: When I get the sharpie removed from the bevel, it flips the burr. I can not seem to reduce the burr any when I flip it. I can still see the burr under strong light but it is really tiny. (strong light being defined as a 100 watt incandesent bulb about 6 inches from the stone.) I did some stropping, first on copy paper and then on thick cardboard/cardstock but that did help. In fact, it got to the point where I couldn't flip the burr. And I sharpied while I stroped too. It removed sharpie all the way down to the edge. I cut some paper but it didn't remove the burr either. What sould I do?
