OK..I've heard enough. I'm going to have to explain the reason for the deep hollow.
Now this will only work with certain, very sharp knives. When you sharpen you must leave the wire edge. It helps if it is just after a rain so the air is a little heavy}
Stand facing your victim at any distance up to 20 feet. (longer with practice)
Strike as if you were using a fly rod and end the swing aiming directly at the victim.
The thick side of the blade creates a vortex or high pressure area between you and the target, shaped like a tunnel.
The very sharp edge splits several atoms in the process.
The split atoms fly around and hit the pressure walls and bounce back splitting more atoms.
Since the only low pressure area is the hole where the target is, the energy all flows that direction.
I once killed a bear at 200 yards using this technique and several razor blades sandwiched between two tent stakes.
