I live in extreme Northern Calif. near the Oregon border. As some of you may know, I work at the Siskiyou County landfill, (the county "dump"). I have the opportunity to get first crack at the "treasures" that come in, (lots of hunters up here). It's a real treasure trove for this sort of thing and since August I've collected many antlers and pieces.
The antlers are from "Mulies", (Mule deer), and Blacktail. I've taken some of the pieces, (crown and otherwise), and have had a great time experimenting with polishing and such. I've noticed that I can get the older, dried out and cracked pieces, (with a little work), to look just like Mastodon ivory. I use very fine wet and dry sandpaper, (wet), and then clean it with green "Scotch Brite", (also while wet). Then I just air dry them. They look great and feel so good in hand.
My question is; "What do you use to stabilize this stuff and does it make very durable scales and handles?" Also; "What do you use to dye the stuff if different effects are desired"?
Since I've accumulated so many, I'd like to use some of it to make some scales and handles for some old folders and fixed blades I have. Any suggestions would be greatly appreciated.
