Originally posted by SlayerPlayer:
Could you describe your Four Walls deflection if you don't mind, ....
Slayer,
I'll give it a shot, but you know how descriptions of techniques can be
For the sake of this description, let's assume a right lead with stick in right hand - but can be done on either side.
Let's start with deflecting a blow to your upper body coming from your left. Hold your stick out in front of you and make sure there's a 90 degree angle between your stick and forearm, and another 90 between your forearm and the largest knuckle of your index finger (the knuckle that you hit with in a standard fist). Position your elbow in close to your body, with the punyo in front of your right hip. Aim the tip of your stick at your opponent's center-line. NOTE: the tip will now be aimed (more/or less) at the center of their face. Place your open left hand on top of the base of the thumb and wrist of the right hand. As the blow comes, you shift the punyo to the left hip, as you keep your 90 degree angles, the elbow close, tip on their center-line etc. At the moment of impact roll your wrist in the direction the blow is coming from. NOTE: the shifting of the punyo is affected body rotating the upper body. To deflect a blow coming from your right, shift the punyo back to your right hip. To deflect on the low line, just turn your wrist over so that the tip of your stick is aimed at their center-line and their feet. By shifting from side to side, on the high & low lines you have the "Four Walls" or "Cuatro Cantos" of Pekiti-tirsia.
Key points: maintain the 90's; keep the elbow close to your body; keep the tip pointed at their center line and the punyo in front of your hips; move your body around the tip of your stick; and roll the wrist at the moment of impact. "Side Stepping" footwork can be added to aide in moving your body around the tip of your stick.
As you shift from side to side (keeping the tip on their center-line and punyo on your hips) you'll see that your stick defines triangles between your body and theirs. This turns your stick into a wedge that deflects on the high & low lines.
To practice, have an opponent throw horizontal strikes on the high/and or low lines as well as diagonal strikes on the low lines as you move in on them. I personally don't like it against a high line diagonal strike. I prefer to cut those.
This is a very effective corto range deflection, that when done correctly will allow you to literally walk in on your opponent.
I hope my description makes sense. It's much easier to show than to describe.
Respectfully,
Dave Fulton
Full Contact Martial Arts Association.
"As iron sharpens iron, so one man sharpens another."
[This message has been edited by Dave Fulton (edited 01-24-2000).]
