I'm not positive about this, but I think it's only called a sleeveboard if in pen form, blades at both ends. If in jack form, then it's called a regular jack or a swell end jack. This GEC #78 American Jack is the same frame as the #79 Workhorse, only in jack form.
Interesting! I hadn't heard that as a distinction (sleeveboard vs. swell end jack), only as one description trumping another. From an earlier
pattern ramble (sadly, Blues's image link is now broken):
Perhaps?
Going off of that thought, however: does a sleeveboard pattern typically have its main blade at the larger end, thus distinguishing it from a swell-end jack (as one example) that would have its blade(s) at the smaller end?
~ P.
On a sleeveboard jack, (both blades on same end), most had the blades from the smaller end but either method of construction was common enough.
On a sleeveboard pen, (blades on each end), normally the master blade was on the wider end.
Sooo... is it possible for a sleeveboard jack and a swell-end jack to be two different names for the same thing (not universally, but in specific instances)?
~ P.
The careful observer will notice a difference in the elongation and swell between the patterns. It is sometimes subtle but where the sleeveboard is generally straight sided with a rounded end, the swell end...well, swells. Look at some images of (especially) older patterns and you'll see the difference pretty clearly.
Hang on a moment and I'll post an image just by way of one example...
Subtle, but nonetheless not a sleeveboard:
In person the gentle swell is a bit more apparent and it has a bit of a "waist". The sleeveboard would be more rigidly straight sided until the curved end (like the ironing board) in most cases.
Companies did and do take liberties with the nomenclature.
Thanks, Elliot-- pictures really do help. I would not have called the above knife a sleeveboard, but have seen some (what I now know to be) sleeveboards called swell-end jacks.
Most illuminating for me so far is that neither single spring nor pen configuration has anything to do with defining a sleeveboard. The Venn intersection of sleeveboard knives I've seen that also contained those two features had led me to wrongly conclude otherwise.
~ P.
Sleeveboards also have the master blade coming out of the wide end of the knife.
Take from that what you will. I do enjoy these pattern explorations-- better yet with knives in-hand, although that is a rare treat. I'm grateful for everyone's specific examples, as pictured, in the meantime. :thumbup:
Speaking of which...
This may count. My GEC 26 in Primitive Bone, a small sturdy knife with monster snap
I can't tell you how much I'm enjoying seeing
your pictures of the knives you've mentioned throughout.
The sleeveboard has revealed itself to be one of my favorite patterns, if the jack form is acceptable as "sleeveboard."
To whit:
GEC 25s - Gots em?
and
Photos and Impressions: GEC #79 Workhorse Whittler (3-spring)
Finally, don't miss Lambertiana's photographic look here:
The Old and the New - Sleeveboard
Such goodness shared, here in our midst.
