Okay, that example was muddy, too.
For me, it suggested that S30V at a hardness of RC58 needs to be thicker than S30V at a hardness of RC61 to handle a low edge angle without rolling. While the RC numbers probably differ, that generality is probably true about most steels.
We can get into the geeky stuff about carbide fraction volume and such, but my experience has been that unless you're going for edges so thin that you can only see the blade on a full moon at a crossroads, it only explains why some steels sharpen quicker than others and why some steels roll when ground too thin for your uses and others roll and crack.
My examples of what I've seen involving carbide volume: Hitachi Blue Super steel; as heat-treated by the Takeda Hamono shop; will take an edge that's five degrees per side (Gunmike1 has sharpened a similar knife to 4 degrees per side). I don't think that can be done with VG-10 or CPM-S90V. But then, if you don't use an closed-cell wooden cutting board and lots of care, that 10-included degree edge will microchip, well, just the way anyone might expect a very thin, barely tempered piece of steel to chip when being repeatedly slammed through food into hardwood (will slice forever, though). On my Kershaws, I kinda sorta overground the edges my External Toggle and SG-2 Blur (they're okay now, though) for their given tasks. They have deep hollow grinds which may regrinding easy and I like my edges waifer-thin. So I screwed up and made the ET too thin to twist while cutting plastic and the Blur too thin to cut unsupported wire ties (but just right for cutting chores done by people who aren't cuckoo in la cabesa). When those edges rolled, the 13C26 of the ET was just rolled and the SG-2 of the Blur was cracked. Resharpened 'em at slightly thicker angle and avoid wire ties with them and problema nada.
So all of that above explains some "edge stability" stuff that won't and shouldn't matter to most anyone.
Where it might matter is if you're absolutely obsessed with having edges sharpened to 10 degrees per side and staying just above shaving sharp after the initial sharper edge wears away. Should also matter with woodworking tools.
That's my take on it, but the smarter folks should chime in soon.
