So, I decided to change my Delica 4 pocket clip from "tip up", to "tip down" carry. When I did so I noticed that opening up the blade was stiffer and dropping the blade down with momentum was the same as well. So I loosened up the screws a small amount at a time and it started to get better. Mind you, I hadn't over tightened the screws to begin with, or so I thought anyway. I'm a bit worried now that the screws may have bit into the pivot washers causing the not so smooth opening and crushing them. I didn't think something like this was possible just by changing the pocket clip position. There is no way of knowing if damage has been done withing taking the knife apart. I will not do that of course.
Anyway, I'm able to slide the pocket clip side to side ever so slightly, I never noticed this happening when the clip was in tip up position, is this normal?.
By the way, I used a "Picquic Stubby" multi-bit screwdriver with Mastercraft S2 Tool Steel, T6 Torx screwdriver bit. I had also read Spyderco's "Edge-U-Cation" about "Changing the Position of Your Pocket Clip", it was in front of me while doing this procedure.
