Delta 5 Chute knife
I may be in the wrong forum and if so then please move to the correct one. Thanks. I have been wanting a fixed blade knife in the 5.0" range for sometime now. I finally went ahead today and ordered the Delta 5 Chute Knife kit from knifekits.com. I did some reading on knifekits forum and these seem to be good using knives. They have AUS-8 steel, a blade length of 5.0" and handle of 4.75" for a 9.75" overall length. Another plus is the thicker blade stock of 3/16". I also ordered a kydex knife sheath kit which will probably prove more difficult to do right than the knife will!!:eek: :D I was between the modern bowie and the chute knife but went with the chute due to the top grind. I also got the cocobolo predrilled scales just to make it a little classy looking! I was looking at some of the knives that have been done and really liked the one without the top bolster. Of course I also liked the ones with the top bolster, and the ones without bolsters!!! Anyone any experience on these? Any one used a completed knife and what you thought of it?
Here's a Kit knife forum that focuses on the KnifeKits models: http://www.knifenetwork.com/forum/forumdisplay.php?f=19
I have a spearpoint Delta5 kit that I've been trying to find time to build. Quality seems really good. I've built a couple of knife kits and a couple of kydex sheaths and the kydex is generally a lot easier. Mostly because there are so few steps involved.
Make sure to come back and post pics here when you're done! Good luck.
I'm a huge fan of kit knives, and the Delta 5 models are among my favourites. I have a drop point and a spear point, and I've found them to be enjoyable to put together and of a high quality. Some advice: if you plan to use the knife regularly, you may want to consider thinning the bolsters, or at least tapering them and rounding them off. I assembled one Delta 5 with the bolsters at close to full thickness, and while the finished product looks nice, it is quite heavy and 'clunky' in the field. On my drop point model, I removed the rear guard and added some thumb serrations, as well as thinned and tapered bolsters - the finished product is much more functional, and nicer looking to boot.
Here's a few shots of my spearpoint as it was nearing completion:
The arctic skinner from knifekits.com is a sleeper hit, in my opinion. It is extremely comfortable, has a strong tip, and slices like a razor. It's also a great deal easier to complete than models with bolsters, which makes it a good stepping stone. I've also completed the Gentleman's Companion and Sensei models, both of which were a blast.
cutter17 - I agre with you on the sheath part. It's much easier to 'dive in' to knife assembly than it is to get started with sheath making. Once you have a few sheaths under your belt (pun intended!), it will become a lot easier, though.
Have a blast with the kit. I predict it will not be your last.
- Mike
Hey brewthunda, thanks for the info.:thumbup: :D This will be my first ever knife kit, but I feel up to the task of completing it. It helps to have access to different tools!
Thanks Mentor! I'll bet it won't either! Already thinking about the bowie without a back bolster! Unfortunetly, I can not see your pics, but I'll bet they are nice!
What tools do you folks recommend having to work on one of these? I've wanted to get ahold of a fixed blade in this length range AND I could use something to occupy some time over summer break, but being a comp sci major doesn't really avail you to stuff you'd often want for working with metal.
Similar query about what should be gotten to make sheathes.
Well, if you're looking to put together a kit knife with bolsters that are pinned on, you need:
- a peening hammer
- an anvil or similar metal surface
- epoxy
- sandpaper of various grits
- and some means of doing small grinding / cutting / sanding / drilling work. A variable speed Dremel with a selection of cut-off wheels, sanding drums, grinding surfaces, and drills would be ideal. Theoretically, you could get away with sandpaper and files, but you'd be in for the long haul.
of course, a respirator or mask and some eye protection is well advised.
If you plan to get further into the hobby, then a good grinder and belt sander are invaluable. Jig saws, rasps, and drill presses are essential if you're not using pre-cut and shaped handle scales. Once you go all-in, a shop vac or similar dust collection system is a good purchase.
As for sheath making, there are some good tutorials out there that list the necessary tools. I recommend checking out NorthCoast knives tutorials, here. Never, ever use your oven for kydex work when there is even the slight possibility that your wife will be coming home. ;)
Cheers,
- Mike
I haven't worked with any of the knifekit.com fixed blades yet but I can certainly vouch for the the quality of their folders. The have an excellent fit and finish. Here's a picture of three of their folders I made up for Christmas presents last year. (handles are paduak wood, cocobolo, & micarta) The AUS-8 blades are cryogenically treated and take a razor sharp edge and holds it very well.
Sun-Yu-Cutter 17 will have to tell you what you need for a fixed blade but if you decide to do a folder you can actually get by with as little as just sandpaper, (400, 600, 1200, 2000 grits) a set of Torx wrenches, (set of Husky Torx Wrenches, $4.95 at Home depot) and a drill. Optional tools that really help are a 1" belt sander, dremel tool and a step drill bit that knifekits sells.
I like what you did with those folders Boozoo. I only have experiece with their folder kits , oh which I am on my 12th , I think , sort of lost count.
At any rate the kits are pretty darn good especially for the price.
A rule of thumb with those kits , even the fixed blades are to make sure everything fits nice and tidy (F&F) before final assembly.
Last kit I did was a slipjoint that I worked very hard on (filework , very nice scales , mirror polish) only to find out once I had peened the pins, I had put the blade on the wrong side....:o hehe lesson learned.
Good luck.
