demo: how to build you own strop
zyhano
Hey guys,
here's a howto post on how I made my latest strop. I needed one for my straight razors and had some questions on how to make strops by various people.
There are many ways to make a strop and here is what works for me at the moment. Another good thread on how to make a strop by sharpening expert knifenut can be found here: http://www.bladeforums.com/forums/showthread.php?t=640503
the results that I get of these homemade strops is this:
attachment.php
hair whittling sharp edges.
So no, you don't need to buy strops to get to this sharp. And if you get to this sharp, do you think that you can really go a lot sharper by spending more $$ on expensive strops? It depends on what you want of course and what you want to try out.
You do need to buy the components to make one, but those can be a lot cheaper.
so let's go trough the process.
what is needed to build a strop?
I bought a piece of pine wood, nothing special, just straight flat pine wood from the store.
You could buy hardwood, mdf even a metal plate etc as well. Do not worry about the wood. Requirements are just that it is straight, stays straight and you can make it in the right dimensions for you. Some woods will be more suitable than others, but this simple piece of pinewood of 18 millimeter high, 94 millimeters width and 2 meters long cost me about $7 dollars in a regular store.
I have bought a piece of leather in the past of about 4 mm thickness, vegetable tanned cowhide from the neck. I bought it directly from a leather factory and it cost me about $40 give or take. This was about 1 square meter surface area.
I've made sheaths of this leather (http://www.bladeforums.com/forums/showthread.php?t=723628&highlight=leather+sheath+sebenza) , experimented with the stuff, used it for maybe about 8 strops, some larger some smaller and I still have about 3/4 left. So this piece will last me a long time I guess. It is not hard to obtain smaller pieces for a smaller amount of money, just be creative.
There are two variables: quality of the leather and hardness/softness of the leather.
Quality? I don't know how to tell you if leather is quality. Just go for a source that you like or trust. It's about the finish, tanning, pores, smoothness etc etc. You can google or search on the forums here to find out more about that.
Hardness and softness? That is about how much the leather depresses when you go over it with the metal and this has everything to do with how straight or convex you want the edge angle to be. An excellent visual guide to this process can be found here: http://www.bladeforums.com/forums/showthread.php?t=750008. The thickness of the leather can obviously play a part in the softness/hardness
I bought some glue at a leather shop which works fine, but today I bought some other glue in the store, both were around $3. Any glue that says it glues leather and wood will probably work fine so don't worry about it. Some glues have a little more give to it than others, making it possible to have less tension on the material when it dries.
Essentially what you need is that the wood acts as a base for the leather. How you fix the two is not really important, it just has to stick together. Of course you wouldn't want something that you'd have to apply in large quantities so it saturates the leather.
You need a stropping compound or paste. I used to go with Cr2O3 (chromium oxide, the green stuff) and got sharp knives, but not hair whittling. I think that is because I bought low quality stuff, and the abrasive particle size wasn't uniform or too large. You can get high quality Cr2O3 and it should be at about 0.5 micron partice size.
I switched to diapastes by the dmt company recently, got them in 6 micron, 3 micron and 1 micron, so I have strops for each variant. The pastes allowed me to get to hair whittling sharp on my knives. You can get all three for around $22 together.
and finally, you need some tools.
In my case, a knife to cut out the leather, a handsaw to get the right length of the wood and some sandpaper. 60 grit sandpaper for smoothing out the wood (the sawcut) and 600 grit to lightly sand the leather. And a pen, to write on the strop what is actually on it.. You don't want to put different pastes on one strop.
Of course, you can make your strop as nice as you want, with wood carvings, handles etc, the works. That is nice if you want to but it does nothing for the sharpness of your knife or razor. So with these simple ingredients, you can really make a difference for the sharpness of your knives and for your sharpening skills.
I hope you all realize that you can vary the dimensions to what you like.
This strop I build here is wider than my other strops, but that is specifically because I want to strop a straight razor with this one.
Other strops might be shorter, longer, less wide, thicker etc.
It depends on what you want.
Remember though, that the more surface area you want, the more stropping compound or paste you'll have to apply to coat the whole surface. This might make you go through your stash a lot quicker.
Some proper stropping technique is also nice, but this is about experience. There's loads of good threads here with good advice on how to strop so I won't go into that here. I also have a video on youtube telling a bit more about this, you can find it here: http://www.youtube.com/watch?v=-HNO8sPhz4Y
So let's go through the whole process with pictures. Total time to make the strop was 35 minutes including making the pictures, sawing, sanding, glueing, applying paste and stropping itself. The time to get the stuff at the stores is not included :)
first, some ingredients. The original wooden board, glue, the diapastes, the leather stuff and a razor blade for size reference
attachment.php
just sawed of a piece of 27 cm long, which is about the length of some of my benchstones. You can see the rough sides, which I'm about to sand with some sandpaper 60 grit.
attachment.php
Here I've sanded off the sharp edges and the sawcut teared edges, with 60 grit sandpaper. I've also done the whole surface lightly, just to get the glue to hold a little better.
attachment.php
Put the wood on the leather, hold it tight and start to cut along the edges of the wood to get the leather to fit. See if you can find a good part of the leather with a 'grain' going in the direction of the movement you make while stropping. You can feel this since it will be softer to the touch.
attachment.php
Close up of how I cut through it. You might make a couple of passes to go all the way through the leather. Be sure not to waste any leather, so pick a good spot and cut decisively.
attachment.php
the cutout
attachment.php
finishing the leather, I just tapped my thumb with the knife with a drawcut towards me. Dumb. Barely touched it, but sliced 4mm into the skin.. more on this later.
attachment.php
here you see the thickness and a littlebit of the structure of the leather on the wood
attachment.php
the glue (contact glue, don't know the english term. Just remember, leather and wood, that's what it needs to glue)
attachment.php
the glue is on there, make sure the edges of both the wood and the leather have glue on it. A zig zag pattern to hold it down in the middle. This will fix the leather, you don't need more than this.
I use the smooth side for stropping with these pastes, so put the glue on the rough side
attachment.php
press on the wood to have the leather and the wood stick correctly, with the leather side on top of the original leather piece. Make sure there is no dirt etc between the leather surfaces because you will embed it in the surface of the strop because of the pressure
attachment.php
sanding with 600 grit sandpaper, to give it a little fluff. You can see the depression on the leather. The sanding brought that out, I didn't see it before the sanding. It's not a problem.
attachment.php
Now, the emerson horseman was hair whittling sharp. You know what they say about sharp knives being safer? This wound closed within a couple of minutes with minimal bleeding as you can see.
attachment.php
proof of the horseman whittling hair... damn sharp
attachment.php
the dmt diapaste, 1 micron, the finest of the three variants of the paste, will give you a mirror polish finish (if you go to this grit by using previous grits correctly)
attachment.php
apply drops of the diapaste on the leather. In the background a Thiers Issard silverwing II straight razor.
attachment.php
rub the paste all over the strop with a non paste absorbing thing. in this case, my finger. Spread it evenly all over the strop and make sure the paste is everywhere. Do not use it all of course, just enough to let the diamond abrasives do their work. They will stick to the strop's surface.
attachment.php
The strop is now a darker color. after the paste has dried (it hasn't in this case) all is good and you can use the strop.
A str8 razor has it's own spine as a built in angle guide so you always have the right stropping angle.
attachment.php
don't forget to mark the strop, so you know what's on it and with what you have to maintain it. In this case, 1 micron diamond paste by dmt
attachment.php
this is all the stuff I used for the strop
attachment.php
These are some of my strops.
A small 'tv' strop, double sided with 6 and 3 micron paste.
A longer strop for normal work on folders, with a handle, double sided.
You can clearly see the discoloration on the strops. With use, the metal that has been abraded from the knife sticks to the strop and gives it a metal coating and look.
And of course, the newly created larger one, for str8's and larger (fixed) blades. This one will be single sided, since I will use it more as some sort of 'bench'strop, like a benchstone, instead of holding it in my hand like I do other strops.
attachment.php
Every once in a while you'll have to apply new paste, you'll notice when the strop isn't going as good anymore. Just put some new drops on there, rub it in and you're good to go. If the surface is to0 dirty, you can clean it up by trying to get some of the metal slurry off or by lightly sanding the surface again.
Be sure to keep the surface of your strop clean of dirt and sand etc. It will not be a good thing if you want your blade to be ultra sharp to have sand on the surface. Make sure the leather does not dry out and just take care of it and you'll have it for a good time. And as you can see, you can always build yourself some new ones :D
As a final step, you can also build a strop with bare leather and no paste or compound. Although there are more opinions on the subject, for me, it does help in getting a little more sharpness.
Enjoy it guys, hope you got something useful out of it :thumbup:
Feel free to comment or to add stuff I forgot.
Nice job zyhano. Does the DMT paste work good on and last on leather? I thought you were to use it on hard wood. That's what I have been using and I just don't like the way it feels while stroping. I would much rather use leather.
Very nice :)
Prime, balsa will give you a similar feel to leather and still keep the compound working fast. Using it on leather will slow it down some and make its finish finer.
I couldn't find any balsa in my area and I have some leather left over from making my other strops so I guess I'll try this way. My understanding is that the DMT paste doesn't dry into the leather. So how do you store your strops when not in use? Do you put them in plastic bags like DMT suggests with hardwood strops?
I've got two drawers filled with strops that aren't in use. No plastic bags. The ones that are in use, are;
hanging strop an a hook on the wall
Bench strop on my computer desk
Bench (leg?) strop next to my place on the couch for TV watching
Stitchawl
OMG! I made some new strops using zyhano's method for my DMT paste and got way better results much faster than with hardwood. Maybe it's just the way I strop. But this is what I did to my Insingo.
Hair doesn't stand a chance. :D
Stitchawl
Aren't you gonna mention the one hanging next to the toilet paper??
Nice job Z!!!
Great job and great post.
Love the many pictures you made.
I need to buy some leather and try making my own!
That looks great.
Did you hit the diamond stones first and, if so, what order did you progress through, including the paste?
That looks great.
I have been touching it up on the EF stone. Then using green compound. This is the first time I went through the 3 DMT pastes.
Funny. I just made my first one last night. I thought I read somewhere NOT to glue it to the wood. Something about allowing the leather to stretch while stropping?
