Let's start with some specs from BladeHQ:
Overall Length: 8.875"
Blade Length: 3.75"
Blade Thickness: 0.16"
Blade Material: D2
Hardness: 60-62 RC
Blade Style: Modified Drop Point
Blade Grind: Flat
Blade Finish: Stonewash
Edge Type: Plain
Handle Length: 5.25"
Handle Thickness: 0.78"
Handle Material: G-10
Handle Color: Black
Liner Material: Stainless Steel
Weight: 7.90 oz.
Pocket Clip: Right/Left Hand, Tip-Up
Knife Type: Manual
Opener: Thumb Stud, Flipper
Lock Type: Liner Lock
Brand: Dendra
Model: Typhoon
Designer: T. Antonevich
Country of Origin: Italy
I just got the Dendra Typhoon made by Lion Steel and I was very impressed at first. It came very tight out of the box as advertised and that was not a problem with the handy pivot tool. Thankfully the pivot will accommodate T8 Torx heads as well. The lock up was very strong and solid, albeit fairly sticky. That should wear in over time though, like most Lion Steel knives.
The ergonomics are wonderful: it's incredibly comfortable in the hand. The blade is also ground to a nice thin edge which I like on my knives. The texturing on the handle is very grippy but not too aggressive. The edges of the handle are all perfectly even and there are no sharp corners.
As with most of my knives, I wanted to disassemble the Typhoon to clean it thoroughly and lubricate it when I got it. It may just be that the tolerances were very tight, but mine was incredibly difficult to disassemble. The back-spacer was an INCREDIBLY tight fit on the screw posts that ran through it. However, it was not too much trouble to take apart.
The big problems came when I wanted to put it back together. I was able to put all the pieces back together without too much effort, but when I went to tighten the screws things went bad. Every screw aside from the pivot broke just under the head as soon as I got it anywhere near tight. I'm not sure if this is a fluke, but that seems unlikely considering every screw broke. I immediately composed and sent an email to Lion Steel and I am awaiting their reply.
I am not sure what my options are when it comes to having it fixed or the screws replaced by Lion Steel, but I will most likely be modifying it. I got it to be a user anyway. I'm going to see if replacing the solid back-spacer with some standoffs will make it easier to clean and maintain along with some new Phosphor Bronze washers to replace the Nylon washers it came with.
I apologize if this is not the correct category or format for a thread such as this, but I wanted to share my first impression and first experiences with the Dendra Typhoon.
Blade Length: 3.75"
Blade Material: D2
Hardness: 60-62 RC
Blade Grind: Flat
Edge Type: Plain
Handle Color: Black
Weight: 7.90 oz.
Knife Type: Manual
Brand: Dendra
Model: Typhoon
