It looks like a lot of people are interested in this so I thought it might be a good idea to start a thread devoted primarily to this topic.
I have almost zero experience in this other than, as a physiologist, I'm very familiar with research on desert animals and the physiological and behavioral mechanisms they employ for survival. This has some crossover into human physiology.
For instance, camels have a thick fur that insulates their body. This is essential because the ambient temperature exceeds body temperature, so the flow of heat is down the concentration gradient, from the ambient hotter air into the cooler body. Most of us experience just the opposite in nondesert environments. So if you are in the desert,this is an important reason to cover up during the heat of the day.
Another reason for thick fur on the camel is that it protects the evaporative surface of the skin. Sweat is used to cool the camel (and ourselves as well) by evaporative cooling. The idea is for the sweat to absorb heat from the body and carry it away by evaporation. However, if the evaporative surface is exposed to the sun, the sweat not only absorbs heat from the body, but also heat from the sun. This is a very inefficient use of sweat. It's better to protect the sweaty surface from the heat of the sun so that as much as possible, the only heat absorbed by the sweat comes from the body. You will save a lot of water this way. Thus, many desert dwellers are covered in loose fitting robes that 1)insulate the body from an influx of heat and 2) insulate the evaporative surface (the skin) from the sun.
One last interesting point is that camel hair is tipped in black. Black absorbs heat but the absorption occurs right at the surface so that it is trapped there and removed by convective winds. So desert dwellers often wear black outer robes instead of white, which they use instead as an under-robe.
The camel has many more adaptations for desert survival but these are the most applicable to our own survival.
Also, here are some desert survival links that might be worth checking out:
http://www.ci.phoenix.az.us/FIRE/desert.html http://www.etisurvival.com/des.htm http://www.ca.blm.gov/surprise/rttips.html http://www.desertusa.com/mag98/dec/stories/water.html http://www.desert-survivors.org/survival.html
Hoodoo
And so, to all outdoor folks, the knife is the most important item of equipment.
Ellsworth Jaeger - Wildwood Wisdom
Hoodoo
