Detentrock?
Hi!
I got I pretty new, not used 31 and notices som "detent rock". I do not feel that the funcion is affected. But the tip is possible to toch sometimes. I have no other knife with this problem. Any More? And how can I solve it, without sendeing the knife to the HQ? (I have tried to oil it and also put on some Fluorinated Grease ).
Thanks!
You are a newer member and maybe missed this loooong posting:
  • Like
Reactions: BBW
Hi!
Thanks!
You are saying the tip touches the standoff when the knife is closed?
Hi!
Sorry, I expressed myself vaguely. It happens when the knife is closed. The blade has a small movement against the detent. I can touch the tip. Have had the same problem with other knives but never with a Sebbie ...
I haven’t had any of this on my CRK’s. However, it is a mechanical pinch that holds the detent/lock ball into the lock bar. If it doesn’t rattle when shaken in the closed position, I’m not sure I would worry about it.
If it bothers you, send it back to CRK, I’m sure they will get you sorted.
