Hmm, as to my knowledge all diamonds are monocrystalline, something like so-called polycrystalline simply doesnt exist. Each diamond particle, even this the smallest, is always monocrystal by its nature, isnt it? Trying to search this matter, for example the difference between DMT and Eze-Lap sharpening surfaces, I came to consideration that both use the same kind of diamond dust. The only difference is that in case of DMT it has significantly more uniform grain size and better embedding on steel surface what makes DMT sharpeners more durable but also more expensive.
Returning to Dia-Sharp series sharpeners. They have continuous surface as distinct from basic DMT line where the diamond coated surface is interrupted with round, plastic-filled holes. The advantages of continuous surface are:
- It provides better sharpening of very small edges, pointed tools or very strongly curved edges. In fact this is not too essential for knives...
- It sharpens faster than interrupted surface with the same grit because the edge meets more diamond particles at each stroke.
- It sharpens somewhat more uniformly because of more uniform abrasive particle dispersion on the surface (there are no particles in holes at all).
The disadvantage is the higher price of continuous (Dia-Sharp) sharpening surfaces in comparison with basic ones.
OK, finally the original question can they wear out? This depends on what exactly you are considering as
wear out. If you think about loss of flat surface and coming concave in lengthways direction and convex in crossways one like it occurs with natural stones no, they cant. Simply because the diamond-filled layer of nickel over steel what makes abrasive surface is very thin and there are no space where to come concave or convex.
However if you are speaking about loss of abrasive properties yes, they can. Relatively soft nickel plating will wear out and lose more and more diamond particles until entire surface will come totally bald. This is theory, I suppose that properly used DMT sharpening surface could outlive you and serve your sun as well.
But be careful it is possible to cause fast wear out using too much pressure when sharpening. It is impossible to break diamond particles as themselves, however it is possible to dig them out of relatively soft nickel plating destroying expensive sharpener irreparably.
In fact it is not necessary to apply any hard pressure when sharpening. Diamond particles have much sharper edges than any other abrasive ones and they do their job well even at relatively light pressure.
