Diameter of the wire used in wire pocket clips?
What diameter (in decimal or fractional inches) is the wire used to make the wire-spring type of pocket clip I have seen on some Spyderco knives?
It's 1.5 milimeter.
Thank you very much. I'm going to be building a new pocket clip for a friend, and needed to know what size wire was comfortable and would fit the socket indentation in the knife. This way I can order the wire now, before measuring his knife up.
Once again, thank you. Your help is much appreciated.
Good luck with your project. I also made a couple (low ride) wireclips using 1.5 mm steel wire, that's how I know the diameter. ;)
