- Aug 4, 2016
Hello i was wondering what are some branded diamond stones are made of such as kme, eze lap and others. I know DMT uses monocrystalline, but any info on the others?
The poly will cut faster due to multi facets diamonds but will fracture and wears to no cut. So you have to reapply each knife you do. Mono has a bit less cut due to blocky shape verses the poly. Mono will last longer on a strop and allow you to do several knives before needing to reapply. In the end both give similar edge enhancement and polish.
...Same guy different post...
poly diamond is multi facets so has good removal and polish. It fractures and due to that breaks down and needs to be reapplied for each knife you do. Mono is kinda blocky and more single Edge surface compared to poly but longer lasting and can be used to do several knives. They both give similar Edge sharpness and polish. I have recent post showing the difference in shape so easier to gain visual understanding between the two.
