Link?No experience, but the knifemaking guys here in Austria were selling off some rests at 25 euro/belt, apparently new price was 50 euro/belt, but only if you take a full package (20 belts).
Resin bonded foil, resin bonded cloth and electroplated cloth. Maybe others.Are they glued like typical grinding belts?
Water cooling. CBN's are way more expensive.Diamond won't be good for grinding steel, the carbon it's made from wants to combine with iron at high heat. Cubic boron nitride is what you want.
Unless you have 1000 psi coolant you wont get away from the localized heat of the diamond cutting through the steel. N navasky is correct, diamond is not ideal for cutting steel when any kind of high heat is present. It will break down and get stripped away quickly. So I doubt heavy grinding (sparks) would work at all.Water cooling. CBN's are way more expensive.
Finishing only.Unless you have 1000 psi coolant you wont get away from the localized heat of the diamond cutting through the steel. N navasky is correct, diamond is not ideal for cutting steel when any kind of high heat is present. It will break down and get stripped away quickly. So I doubt heavy grinding (sparks) would work at all.
Looks like it time for diamondsI have been using the ceramic Trizacts for a while on S90V and Magnacut at 64 HRC and they work pretty well and last a while. Norton also has the U936 as well that are ceramic, too.
After the A16 Norton Ceramic U936's, damn those pesky deeper scratches in S90V!
