Ditto to what others have said. They can & will work fine with a light touch. As a thumbrule, when using them on simpler & less wear-resistant steels like 1095 and low-alloy stainless, etc., it's best to use a finer grit for heavier tasks, like rebevelling, as compared to the generally coarser grits that might be used for the same task with other less aggressive stone types. Diamond is plenty aggressive enough, even at relatively small grit size; too-coarse diamond hones are overkill on simpler steels, and will remove more steel than necessary and leave the edge pretty ragged. I've seldom felt a need for anything beyond a 'Coarse' or 'Fine' grit for rebevelling on such blades (pocket/folder-sized or small fixed blades), assuming a 6" or larger hone.
Learning the right 'light touch' for a diamond hone on simpler steels will pay off across the board, with other stones and knife steels.
And regarding maintenance of the hones themselves, they're the easiest to take care of and keep clean. Dish soap, water and an old toothbrush, plus perhaps 1 or 2 minutes of scrubbing will keep them clean-as-new. Rinse them in hot water & let them air-dry (hot water rinse speeds this up) completely, before putting them away.
David
