- Apr 28, 2007
I recently aquired this knife. It has two blades, a clip (2 1/8") and drop point (1 5/8") on the same end of the knife. The larger blade is marked Diamond Edge 362 Stainless and has a crown inside of a diamond shaped frame. It has STAINLESS, IMPERIAL, PROV. U.S.A. stamped on the tang. The small blade is stamped: STAINLESS. The bolsters appear to be Nickelsilver and the scales are dark brown plastic (?), rivets are brass as are the liners. There is a oval shield with a dimond shape containing D E with an arrow through them. I know that Diamond Edge was aquired by Imperial around 1960 and since stainless steel was still not being used in most knives then, the emphasis may place the age of this knife to about then. I would call this a "pen" knife if the blades were on opposite ends. Does anyone know more information? Thanks.
