- Jan 22, 2012
I will be constructing some strops and have already received the leather. HandAmerican 6" by 12" leather.
My plan is to cut the leather into 3" by 12" pieces and mount to a 3" by 3" block that is 14" long. I have the blocks.
I have received some 3 micron Chromium Oxide powder that I will load onto one stop (rough side).
Correction...
I have one tube of TORMEK at 3 microns and the chromium Oxide is 0.3 microns (from Kremer Pigments)
I received 2 tubes (5grm) of diamond paste (monocrystalline). one tube is 6 microns and the other is 1 micron.
Question is what side of the leather should the diamond paste go on? The "smooth" side OR the “rough” side?
BTW I also purchased the Work Sharp sharpener and received it at work yesterday. Worked quite well and I amazed some of my fellow workers who had dull pocket knives
BTW#2 I have also ordered a number of intermediate grit Micro-Mesh belts up to the Micro-Mesh 12000 to use with the Work Sharp. Did get some extra 12000 belts and was going to try installing them inside-out and use as "strops" and load the belt with some of the diamond paste and chromium oxide and see what happens.
A small "learning" curve with the Work Sharp to keep from rounding the tip. I have to work on that
Thanks,
omi
Correction...
Thanks,
omi
