I don't know what you mean about angles being not correct.. If you mean that the marked angle is not what you are getting, then you are absolutely correct - except that that is precicely the reason why DMT doesn't even have any angles marked! The resulting angle depends on the width of the knife blade. So the angle Lansky gives is just some estimate - and if Gatco has some angles specified, then those are also not correct either. (Unless the knife is clamped somehow differently to it?)Originally posted by ZUT&ZUT:
Hi,there.
Gatco system has the best "jig" and is second for the diamond hones.
Lansky has a useful "jig", unfortunately the angles given are NOT correct, the diamond hones (IMO) are last of the three.
DMT has a weak "jig", the angles given are also NOT correct, but the hones are SUPER.
