- Dec 12, 2019
Hello,
I’ve been having trouble with some dmt diasharp Diamond cards, when it comes to sharpening Buck knives. I have the trio - course, fine, and extra fine, and I rubber band a 15° angle guide to the end of the card and proceed to sharpen. I’ve used the angle guide method with whetstones (regular, not Diamond) and the Spyderco double stuff, and it works great for building the muscle memory of how to hold the knife for the proper angle. I got the cards because I just wanted to experiment with a different method without dumping a bunch of money on the full dmt stones.
The problem I’m having is that the Diamond cards are scratching up the blades noticeably (and not really sharpening them much either). I first tried with a 420HC Buck 112, and it barely sharpened the blade, but left it’s mark now permanently. I then took the blade to the double stuff, using the same method, and it came out hair popping in due time, with no further damage.
I just purchased one of Buck’s Heritage series - a 102 in D2 steel. The blade came unusually dull for a Buck knife, and I’ve read that D2 really needs something like Diamond to sharpen in a reasonable time. I tried the spyderco, and it barely made a difference in sharpness. Then I tried the Diamond cards and… same results. Scratched up my blade, and it is no sharper. For this effort I was using the fine grit.
So, I’m using an angle guide (I’m not dragging the profile of the blade clear across the diamonds), I’m using little to no pressure, just using basically the knife weight, while holding it steady… can anyone tell me what I’m doing wrong?
Both knives are users, so the scratches aren’t the end of the world, but it’s not my preference either, and if I can avoid it, I’d like to. I’ve been looking into buying some dmt diasharp stones, but if I can’t do anything except damage my blade on the cards, I’m not going to drop cash on a larger version of that.
Any input would be appreciated, thank you. I’ll try to load some pictures. I’m not really sure how… do I have to use photobucket or something? Are we still stuck in the MySpace era of photo uploading?
