- Oct 20, 2004
So I finally got my diamond spray today. I have 2 strops that I bought awhile back and tried using the Sears chromium oxide without much luck. So I cleaned off the green stuff and put 1 and 0.5 micron on the 2 strops.
I took my fairly sharp M4 Benchmade Rift to first the 1 and then 0.5 micron strops and made maybe 20 passes on each side on each strop. Now the knife is noticeably if not significantly sharper. It pops off quite a few hairs holding the knife above the skin and it splits a hair if you hold it just right. I think it can probably still get quite a bit sharper and I'm sure I have a long ways to go on my technique. But so far I am pretty darn impressed! I will be trying different knives to see what other steels do and also to see how much I can sharpen with just the strop. I am curious if a blade is shaving but losing it's edge, if just stropping will bring them back to hair popping without having to put them on a stone?
I also got some freebies in my order and not real sure what they are for so thought I would ask. One is a piece of felt. I have read that this is good for taking off a burr or wire edge. I read both to slice into it to remove the burr and to strop on it between stones. Does anyone have any experience with it? It is about a 1/4" thick. I was wondering if I could cut off a small piece and put some diamond spray on it and make a little sleeve for it and use it as a mini strop when away from home?
I also got a large piece of leather and it looks like it could almost be a razor strop without the fittings? It is hard but not super smooth. It has almost a suede look but it is about 3/8" thick and hard. Any ideas what it would be best for?
There was one more item, a piece of leather that is really 2 pieces glued together. One side is smooth and looks like the leather on my bought strops and the other has a real small square pattern pressed in. Any ideas?
I guess I could call but figured I would ask here first. Thanks and sorry for the long post!
Ryan
BTW it is all Hand American product. It has been a long trip but I finally have it and it seems top notch so far!
Ryan
