I'm considering buying a few DMT dia-sharp plates and what I read here seems very positive. I just wonder if it will work faster or better than what I'm using now.
What I want to do:
1. Normal sharpening of my knives and the knives of others. Mostly basic stainless steels. I sharpen almost everything to 15 degrees (per side) with a 20 degree microbevel.
2. Experimenting with reprofiling high quality steels to smaller edge angles. I want to practice on some mediocre to crappy knives that I have and then take my brand new Delica FFG ZDP-189 down to 10 or 12 degrees per side.
What I've already got:
1. Norton combo 8" stone with medium SiC on one side (about 180 grit) and fine AlO2 on the other side.
2. Spyderco Profile stones in medium and fine.
3. Spyderco sharpmaker with the basic stones.
4. A couple of leather strops loaded with cheap hardware store green compound.
I use the medium SiC for setting initial bevels and getting a burr on both sides. It works fairly quickly. Will diamond work faster or better? Reprofiling even from 15 degrees down to 12 or 10 seems like a lot of steel needs to come off. I generally use either the profiles or the sharpmaker for polishing the microbevel once it's set. I strop some knives but not others.
If I do get the diasharps, I don't want to get a full set. I've read a half dozen threads about the subject. Some have recommended just coarse and extra fine. I wonder, will coarse take metal off fast enough for the type of reprofiling project I have in mind? What if I only bought X-coarse and extra fine? Several people say the gap from C to XF is not a problem at all. What about from XC to XF?
This is maybe too much to ask all at once. Thanks for any consideration and wisdom you have to share.
Brian.
What I want to do:
Brian.
