- Dec 19, 2018
I am of the opinion that Buck 110's started being made in 1964. Another person is going by the sheet of date codes that shows 1961. Which is right? The data sheets were written by Joe Houser.
It is pretty cut and dry.... sort of. If you look at ..
* Joe Houser's 110 data sheet in the sticky above it lists 1964 as the first year.
* 2014 was celebrated as the 50th anniversary... 1964 to 2014
* Buck issued a 25th anniversary 110 in 1988... that would imply 1963.
* The date codes only tell us that the 'BUCK' only stamp started use in 1961, not that the 110 was introduced in 1961.
* Historically, I believe the idea was conceived in 1962, designed and tooled for in 1963 and after some delay, finally hit the stores in 1964.
And going along with your and Skyler's comments I would add that the '64 catalog was in all likely hood prepared late '63.If I remember correctly the 1964 catalog had a flyer attached that introduced the 110.
