My guess is that it will work best on high wear resistant, high toughness steels, but I could be totally wrong lol. It looks like to get the most out of the dual grit edge, the burr needs to hang onto the apex for as long as possible.And , how would that sharpening method work with other steels .. ? ( Would the bur Roll ? ) Or is it only good for the top of the food chain steel ?
Short answer is yes. Best answer is it depends on how that steel takes this edge. It's not just about being a super steel. In some that I've seen Pete will test different finishes on the same knife. I think thats what I've seen him called. He cuts rope n I wonder if he knows in total weight how much rope hes cut. I don't get it tho. Why is pete using cedric and adas youtube channel? Does anyone even know if cedric and ada are ok?
Thank you. Do you have a link?Short answer is yes. Best answer is it depends on how that steel takes this edge. It's not just about being a super steel. In some that I've seen Pete will test different finishes on the same knife. I think thats what I've seen him called. He cuts rope n I wonder if he knows in total weight how much rope hes cut. I don't get it tho. Why is pete using cedric and adas youtube channel? Does anyone even know if cedric and ada are ok?
