To differential temper a knife requires that the part you want to harden be heated to the critical point of that particular steel and cooled at a rate fast enough to harden that part without hardening the rest of the blade that doesn't require holding an edge.  You can differential heat treat with clay or certain types of cement applied to the parts that you want to stay soft.  I use the heat treat oven to do this as it brings the whole blade up to temp. and when you quench, the center of the clay will cool to slow to harden the steel.  This usually will only work on fast quenching type steels; 1070,1095, 5160, 52100, etc.  O1 will not form a temper line due to the approx. time needed to harden (10 sec.).  It doesn't work as well on knives with less than a 6 inch blade either.
If you temper at least half of the blade, the back of the clip for about an inch will be hard any way.  That will be what is most in contact on the backswing anyway.  If I were to carry a knife with a sharpened clip(a few times), don't let ANYONE hold it because they always have to touch it and start bleeding.  A dagger is about as legal here as a sharp clip and every one knows both sides of it are sharp.  Didn't mean to ramble.  Ray Kirk
