Haha- this is an area I can actually be helpful with. I haven't tried any sort of cryo treat, and I haven't used clay yet, but I've done a tests on diff. tempering. What I did was closer to diff. hardening. You take the blade and dip only the edge of it in oil and rock it back and forth, then after several seconds, dunk the entire thing. You get a visible division. The part that was quenching the entire time (the edge area) with appear darker, a smokey color, and the part above with be a lighter grey. Look at Brian Goode's work for fine examples of this. The edge hardens very nicely ( I can't say that I've done an RC test, but but it held an edge better than my buck knife without being impossible to sharpen), and the spine is relativley soft. The best thing about this method of tempering with O-1 is that you have several tries to get it to your liking (O-1 is very forgiving in this area). You may need to use something to bring out the temper line(vinnegar works). On a side note- a hammon and a temper line are two very different things.
Use the search functions for good threads.
