- Apr 4, 2013
I just got myself a mini-grip, my first hollow ground knife and first with 154CM, I had my sharpening setup out today doing some maintenance on other knives and I had planned on reprofiling it to a standard bevel of 20DPS (40 inclusive) because that is what I do all my knives at. I use a set of DMT Dia-sharp coarse and fine/extra fine (600/1200grit) plates and a spyderco fine ceramic stone (~2400grit), I have a leather strop but I don't use it and I don't have any compound, my edges arnt polished coming off the spyderco stone but they shave easily and cut news print so for what I need in a working edge they're more than satisfactory.
I'm just not having good results and I'm wondering what I should change first. What do you think my problem is mostly- the different steel or the hollow grind (convex edge) to normal bevel regrind? The steels I have and sharpen well are VG-10, 440C, H1, Sandvik, AUS-6/8, 8CR13MoV. Is 154CM tougher to sharpen than those?
From what I can tell I've accomplished the regrind, after going up threw the coarse and fine dia-sharp the knife is where it should be, its relitively sharp but is still quite coarse, a good burr has developed, its when I move to the extra fine DMT that things go south. It's not an angle problem, I'm holding that steady. I guess, but I'm no experts, I'm not even really that good...I guess I'm rolling the edge but why? What do I need to do different?
