Dimensions of sex screws?
I had a ton of these awesome stainless black screws from BladeTech that were pretty short (probably 1/8" from the bottom of the head to the bottom of the screw). I ran out. I have longer ones but they're too long for most scenarios. Anyone know the dimensions of what I should be looking for as a replacement? (i.e. 2-56 or whatever?) Anyone have a good source for black ones, either SS that are painted or whatever they do to them or aluminum? I'd like Torx if they're out there, which they probably are, but I can find 'em if I knew the size. Thanks in advance!
Pretty personal topic. I can assure you it's a lot more than 1/8" from the head to the bottom of my sex screw!
I'm not qualified to respond to this question , I'm only a metallurgist !
Hahaha jackasses. Now just answer the dang question, please. I guess I could've said "Chicago" screws, but none of you pervs would've responded that way (not that you really helped at all). :D
Guess I can't really help much either but I do remember from watching a Gene Osborne video that he made a 1/8" thick plate drilled and tapped that he ran a bunch of screws into. He then ground off the too-long parts of the threads flush with the back of the plate and viola!, 1/8" screws. Also, backing them out of the plate straightened out the little burr from grinding.
I have to admit, that's a pretty catchy title! :D
So no one is willing to help out, eh? Bastids. I should've just done this on my own.
:D
Just looked at a screw website (huhuhuh.. he said screw) and it gave the dimensions of our friend the Chicago screw as 8-32 screw with 7/32" outer diameter for the female post. That sounds right to me and all the CS's I've seen in my time in this have been identical, so I assume this is accurate. Now, have fun ya wankas!
i wanna know how you his the s key when you should have hit the h key.....
those are pretty far away
hey you guys wanna get a poll going on for the size of our sex screws?
i think it will help put some things in perspective and Chiro can figure out what he needs to know :D :D :D :D
ROTFLMAO
sorry buddy i had to
