I dont like the fact that there is not enough of either edge style to play to the advantages of both. Also there is really nothing that serrations and comboedges can do that plain edges dont do.
I had a 3 1/2" combo and that was my experience with it.
The other problem I found was that if I wanted to cut something with the plain edge, I had to cut farther out on the blade where you have less control. I found it to be an issue if I needed to cut something that required much force to cut.
The only two folders like that I can think of at all is the Boker Direkt, a CLB design... and the Victorinox One Hand Trekker.The question is one that I've been wrestling with.
I would love to find a 3" or under folder that does it all - EDC and hiking, camping work.
I go back and forth between a Spyderco Delica or Benchmade Griptilian - PE or PS
I haven't made up my mind yet although I'm leaning towards the PS just because the serrations require less sharpening when you are hiking.
I do like the idea of the serrations of a PS blade at the front.
Anyone know of a 3" or less folder that has that set up?
What don't you like about a combo blade?
It messes the cutting line. You have the serrations, which are chisel ground, then the plain edge section, which is V ground. Trying to make one smooth slice with the whole blade is nearly impossible.
The Boker Direkt is 3 and 5/8ths, but it's the only one i can think of off-hand that has this setup:
This is a good knife to know about, but I fear that in this case, the cure is worse than the disease. Blade looks like a more useful configuration than the normal combo blade, but the rest is fugly and is not something I would ever carry.
