I copied my friend Bruce Bingenheimer’s setup. It works depending on the individual’s specific setup. Mine:
KMG grinder (non-tilting).
I mounted the motor under my bench and ran a belt up to the drive shaft on the left side of the frame through a hole in the bench.
After seeing Bing’s, I ordered a longer shaft and a pillow block to fit it. The longer shaft sticks out to the left, off the edge of my bench, the pillow block supports it. I then attached my disc to the end of the shaft. Bought a reverse switch for my vfd and now have a disc on the same machine.
For some people, it’s probably not ideal. For me with my work space, it works pretty well. I don’t have to put on/take off an attachment, I can just step around the end of my bench and use it. Was by far the cheapest way for me to get a disc set up in the shop.
Jeremy
