- Oct 24, 2020
Has anyone experienced your disc grinder removing more material at the edges on a flat disc? I'm doing about 30-40% speed. I assume it's a technique issue.
Would a foot pedal switch work, or be advantageous?Getting on and off the disc and the right pressure while you are removing material all take some care. I have a VFD, so I can hold the piece on the disc without it turning, then use the other hand to ramp up the speed. I still stop frequently to measure the thickness at various points on the piece.
there is the highest turning speedHas anyone experienced your disc grinder removing more material at the edges on a flat disc? I'm doing about 30-40% speed. I assume it's a technique issue.
