Famous last words!I dont need angle change just need 90degree...
Thats so easy , thanks sir !Simplest:
Bolt the disc sander to the benchtop and shim if needed so the disc is 90° to the benchtop. Make a riser block from a piece of wood or aluminum/steel square channel that places the top at the center of the disc. Check that it is still 90°. Mount the block from below with a couple of screw-knobs or quick handles.
Is this mono phase motor ? Are this hot wire ??????????????????? If they are , do something to cover them !!!!!!!!!!heres how it looks nowView attachment 1707792
