- Mar 26, 2018
Hello!
I hope you are all doing well tonight!
I am currently in the market for a disc sander. I know there are a few threads on the topic, but I didn't really find a definitive answer to my questions in them.
To start off with, the sander will be more or less used exclusively to square up scales and blocks... And probably quite a few of them. In the future it may be used on steel, but I imagine that is still quite a ways off, as I am still working at becoming proficient in other areas of making a knife.
The first decision I'm trying to make is 9" vs 12". I know that the sandpaper for the 9" will be cheaper since I can just purchase sheets, but I would like to disregard that aspect for now. Results are more important for the time being. I also understand that the 9" would likely be the best bet for future steel work, but would the 12" be significantly better for flattening scales and blocks? I'm not opposed to purchasing a 12" for now, and then purchasing a 9" later down the road when my skills advance.
I imagine if I go with a 12" now for wood, and a 9" later down the road for metal, there would be no reason to go with a 12" VFD/reversible model, correct?
And what about brands? I would definitely prefer to avoid the Harbor Freight Central Machinery model. I would like decent quality, but not crazy overkill. It looks like there are several models all around the same price; Grizzly (I'm biased towards them as there headquarters is just down the road from me), Shop Fox, Rikon, Delta, and Eastwood are all within about $30 of eachother. There is also a WEN for about $50 less than the brands I listed, but I'm a bit unsure about them.
A buddy of mine takes a different approach and uses a spindle sander, but from what I've seen, it seems really inefficient.
What do you think?
Thanks for the help!
What do you think?
