Hey Guys,
Looking for some advice on how to prevent imperfect hole edges around pin holes on a fixed blade I'm working on. I'm not sure if its the handle material, pin material, or my method that is causing the problem. I'm using stabilized maple, but I also tested walnut with similar results. Pins are 316 stainless 1/4" diameter. I've successfully drilled clean holes by using a sharp drill bit and tape but when I install the pins and grind them flush I inevitably end up with discoloration around the hole where small flecks of metal have embedded into the wood grain. I've tried scrubbing them out and I also tried using superglue around the perimeter of the hole to try and reinforce it but similar results. Any one else have this problem, any ideas what I'm doing wrong?
https://imgur.com/Uxtc66a
https://imgur.com/LMmoUlq
https://imgur.com/KSty31V
https://imgur.com/TrI8JZl
