DEllis
Part Time Steel Basher
- Oct 17, 2007
I am not wanting this to turn into a urinating for distance contest, so let's try to keep this civil
In another thread, a comment was made to the effect that there is no reason for forging blades with the availability of modern steels. In my experience, that is a misinformed statement for several reasons, and I hope this thread will increase the understanding of the topic.
One big advantage to forging, in my opinion, is the ability to make blades with much more curvature with narrower stock. For example, if you want to make a kukri by stock removal, you may need to start out with a 5 inch wide(just an example, you need enough to include all the contours of the finished blade) bar of steel. By forging to shape, the same blade can be with bar stock slightly narrower than the widest point of the finished blade.
Another, related benefit, is the efficient use of steel. I can forge a 1.5" wide bowie, 9 inch clip point blade, with a 5 inch narrow tang out of a 1/4" bar of steel 1 1/4" wide x 10 inches long. The minimum size for a stock removal of the same size would be 1.5"x 14"
And, of course, there is no other way to make Damascus steel, which is reason enough to have a forge handy
Thoughts?
Darcy
Thoughts?
Darcy
