- Jan 27, 2000
I was asked in another thread regarding a Bowie I made with a frame handle, to explain a bit about the whole frame handle concept. I decided to make a separate thread for discussion. This way I can give my point of view and others can chime in, and we won't get off topic in the original thread.
In a nutshell, the end result of using a frame handle is a hidden tang knife that looks like a full tang knife. It is not a way to be deceitful. There are valid reasons to use it. First, here is my feeble attempt at an artist's rendering of what a frame handle is:
A frame is made in the final shape of the desired handle for the knife. An area is cut or milled out to fit the tang. The handle material is attached to the frame, then the frame is affixed to the knife. In the picture you can see 5 spots that represent holes in the handle material.
The 4 outer holes are for pins to affix the handle material to the frame. A bonding agent is used as well, but it's primary purpose is to seal the joint. The pins are what creates a mechanical bond. The 5th hole (in the center) is for placing a pin to affix the handle to the tang. Again, a bonding agent is used, but the pin creates a mechanical bond.
As far as the reasoning behind using a frame handle, I can't think of a functional benefit. Perhaps other makers can chime in with that. Here's my reasoning:
I had a piece of ivory which was about 3" wide, 4 1/2" long, and 1/4" thick. I drew a center line down the length if the ivory, then drew and cut out two slabs in the shape of my desired handle. Some quick math let's you know that when the two pieces are put together I would end up with a handle that is approximately 1/2" thick -- not quite thick enough for this knife. So by creating a frame, and attaching the scales/slabs to that, I end up with a wider handle and a knife that looks like a full tang.
So, why not just make a full tang knife to begin with? There would be no way to get the guard an ferrule on. That's one of things I love so much about hidden tang knives. There is virtually no limit to what you can do design-wise regarding the guard and handle.
Now, I leave this open for further comments. Hopefully some other makers can touch on some things that I may have missed.
