Jim I hung two Kuhkuri's on the head of our bed.It is one of the tall water bedframes with a standard mattress and I thought it would be a right handy place and better than under my pillow.
I used a regular wood screw with one of those fancy washers that works in place of a countersink.I scewed this into a predetermined amount of rope with a knot in it for the Hanuman.The scabbard slides inside the rope and catches on the sash buttons.Looks real nice.
The 18" AK is hung on a piece of coat hanger. I cut the bottom section off and using a pair of needle nose pliers I formed a circle to hold the screw. I then made two 90* bends in the rod.The 1st. one right at the circle --O like that then another one about 5/8" up in the same direction to the length I wanted and then formed another circle.The finished hardware looks like this straight on. O-------O The 2nd circle is to keep from getting hurt on as well as allowing the loop in the frog to pass over it without snagging.
I found that when it is installed the longer piece needs turned out about 15* to 20* to let everything work smoothly.Mine now slides off very quickly and smooth and quiet.
Until I made this slight adjustment it would hang up just a tad getting it off and I would have to turn the scabbard to remove it.
Since I am getting so many I am thinking of taking a board and some dowels about 3/4" and 1/4" and making a mounting that will hold several.
I will put equal spaced holes in the board and glue the cut to size and drilled 3/4" dowels with the 1/4" dowels already glued in place and dry into them and make sure everything is
square and even. A person could make several of thee the same size or make them in sizes that would make a nice pyramid shape when hung one under the other. The possibilities are endless.
Sheesh!! I can't believe all the mis-spelled words in that.It seems that I was hangin Hunaman on some fish eggs.hehehe with a not. Does that mean He was hanging by just a smell in mid-air??
>>>>---¥vsa---->®
The civilized man sleeps behind locked doors in the city while the naked savage sleeps (with a knife) in a open hut in the jungle.
[This message has been edited by Yvsa (edited 08 August 1999).]
