- Sep 7, 2015
If you are a Spyderco nut you eventually wonder about byrd knives. They are cheap, they look similar to their much more expensive Spyderco's.
I got this used from a member here, and I was pretty impressed by it. I believe it's an older one so I decided to take it apart and clean it, and see how well it's made.
Despite some rough grinding it doesn't look too bad, they even went to the trouble of lightening up the liners.
This is where the problems begin...
I found a stripped screw. It's stripped because the holes don't line up between the scales and liner.
I wanted to take the knife completely apart but it's hard to see. The lanyard tube is slightly flared out. This prevented me from removing the back spacer.
The other problem is I couldn't remove the lock lever. I tried gently taping on it but it wouldn't budge ad I didn't want to break it.
I forgot to take pics...I never taken a lockback apart before and I removed the spring. I don't know if this will help any one but here's how I found it easiest to install it.
1) Put screws back into back spacer to hold it in place.
2) With the blade removed push the the lock lever all the way down towards the blade pivot. This gives you a little extra clearance to make it easier.
3) Use a tool (I used another knife) to push the spring back underneath the lock lever. Then make sure the spring is well seated and won't push out.
4) Using the lock lever like you would normally to unlock the knife lift the lock lever up away from the pivot. Then replace the blade in the closed position.
Here it is all clean and freshly oiled.
