I'm in the process of making a 2x72" belt grinder. It is somewhat based on the DCKnives online plans. However, I didn't like the way the tension wheel is just mounted atop a vertical post. I figured an arm, like a Bader, would make for easier belt changes. I also saw a production grinder with a gas shock instead of a spring. I figured I'd try that out. I went to Advance Auto Parts and found a cheap on with holes at each end (that you can run bolts through). There were only a couple there that had holes instead of the ball-and-socket attachment.
Anyway, this thing is STIFF! I'm estimating it at 100lbs of tension. Is that going to be too much? It may be too much for me, as the whole point of the arm was to gain leverage over the spring and make belt changes easier. It seems like I have lost that advantage. With this much tension, I worry about breaking belts, wearing wheels/bearings, and so on. What do you think? Is there a better source for such a gas shock? I couldn't find any info on the packaging about how much pressure they exert.
Here are some pics so far. I'm waiting on wheels/belts to come in, and will buy a motor this week. I'm hoping to have it done by the weekend.
