I have two 12" Ontario machetes and one 18 and have always wanted to diy them. Not real knowlegble on blades but handy with tools so ok with any input. Didn't know what I wanted till I saw what bark river did with one yrs ago. So far working on the first 12" Im filing the edge to remove that atrocious secondary bevel (if that's what its supposed to be) and leaving the first 5-6" scandi to make feather sticks and transitioning to a convex to the end with out a defined transition as I saw one guy do. Not removing the shoulder on first one but will on second and leaving black coating on first as its smooth coating but will remove the coating on second one as it was rougher/ more like the bark river. Was leaving the first 1 1/2" on spine to place thumb if desired and 90 deg the next 5-6" for scraping and then rounding last half for hand placement. After those two will go for shortening the 18". Question: Should I sharpen all the way to the tip or leave the last 1" little dull?
Interested in any advise up till now but my biggest questions come from the handle. I have epoxy I do decorations with and can do the epoxy honeycomb you see on knife decorative scales but am afraid that will be to slick for a user. Have lots of reclaimed wood I can use like oak and even some exotic hard woods I don't know what they are but am afraid wood would be better but maybe still slick? What grit do you guys sand to? Like the thought of micarta the most but don't have the material for that and many slabs sold are for knives and a hair to small for this. Any thought on the grips?
After its done was going to cut down the plastic sheath available for them and add a belt clip and use ranger bands to hold a ferro rod and a 6" file.
