- Aug 5, 2014
Title says it all I'm planning on making a clip brake. I'm slowly working through my first liner lock and will probably just use one of the prefab clips I bought but not a huge fan of many of these options. They often look like an afterthought so on future folders I'd like to make clips either "milled" style or bent. The fellhoelter style clip brake is not available anymore but it looks pretty straightforward. I plan to make it using 1.25" and 3/4" aluminum square bar with 1/4" aluminum plate to make the side plates which form the ears that the bending pin goes through. I think the only tricky part will be getting the holes in the ears aligned just right so that it's flush when open. Anyone made one and have advice? The materials in my cart right now only come out to ~$40 as long as aluminum is sufficient which my gut says to bend 0.04" Ti will be fine.
