DIY Izula Sheath Clip
Inspired by fast14riot's Skyline Clip
I wanted to make a clip for Izula sheath.. I normally carry it in my back pocket but wanted to make it a way to carry IWB or just easily obtainable on my weak side.. So what the hell it was Friday, got off work, and I had nothing else to do..
Started with a hack saw blade measured and cut to length as specified by my designs..
Drilled out two holes as I thought at first I would use two small nuts and bolts (ended up using one cause it prevented easy clip on)
After some simple magic elf metal work we got a pretty raw clip to check out..
I need to figure out what I want to do to ensure sheath retention.. Maybe rebend the metal at the bottom to create a "u" to help pocket retention..
Comment & Criticisms Greatly appreciated
Nice work. You can loop paracord between the hole in the clip and the hole in the kydex to keep it from bouncing off your belt. Of course you'll have to slide it on your belt after that.
