After completing my first kit knife I found I could not sharpen the recurve blade on my India stone. After searching through various methods I was fixing to get a spyderco sharp maker, but then I though of this:
[/URL][/IMG]
If you have a miter saw or a way to cut accurate angles you can easily put this together. I cut two blocks at a 15 degree angle and mounted them to a board. I then cut to drumsticks to glue against the 15 degree angles. Started at 220 grit to reprofile then worked up to 1500 grit (highest I had). The result was a shaving sharp edge, the sharpest I've ever been able to put on a knife myself.
It wasn't until I finished that I thought about maybe making the angles closer to 20 degrees. The result is a wicked slicer, I just hope it lasts.
