Hello everyone!
I have been working on something for a few weeks now and figured I'd finally share it. There are many pocket sharpening options available right now, but this may be of interest to some. I like many used to own an older model Fallkniven DC4. Loved its polishing capabilities on the fine stone, but unfortunately I lost it on a backpacking trip. So I have been on the lookout for a suitable replacement ever since. The newer stone's fine side is extremely coarse compared to the older stone and being a bit spoiled by the past, I needed something similar. So instead of buying anymore pocket stones I figured I'd make one for myself. So I am going to show you exactly what I did and if you guys are interested you're welcome to give it a try for yourself! Also, any suggestions for improvement would be more than welcome. Anyway, enough chat.
Here is the idea:
DMT Dia-Sharp Credit Card Sharpener + Arkansas Stone
Seems pretty simple, but I ran into a few problems while trying to achieve it. Number one being, no one makes a credit card shaped Arkansas Stone. If they do make one close in size its usually something like a half an inch thick, which wouldn't be very... portable. So upon contacting Dan's Whetstone the very nice people there informed me that they did have (although its not listed on the website) a 4"x2"x1/4" stone. It usually is bonded to different stone of the same size to make a combo stone, which is why it was not listed on the website. So with the Credit Card Diamond Sharpener was 3"x2" I needed to remove 1" of stone material without destroying it. To fix this problem I purchased an inexpensive 7" tile saw. Measured everything up and made my cut. After the cut was made it was as easy as some water resistant epoxy. Here are the available options:
Dia-sharp
Coarse: 325 mesh, 45 micron
Fine: 600 mesh, 25 micron
Extra Fine: 1200 mesh, 9 micron
Arkansas Stones
Soft: Medium
Hard: Very Fine
Black: Ultra Fine
Any one of these combinations would work but the two that I feel would work best are Fine/Hard and Extra-Fine/Black. Here are some photos!
Fine Diamond Side
Hard Arkansas Side
After the cut
Right to left: Spyderco Double Stuff, JCKT-3, Fallkniven DC4
Same as above
Size comparison
I haven't exactly figured out the best way to round the edges, so I figured I would snap some photos before I possibly ruined something. If I were making it for someone else though or if I were a little more OCD than I actually am, I'd round the edges to match.
An important note about Arkansas Stones, they cut slower than their synthetic counter parts however they also do a good job polishing the edge. So if you do go this route you may have to spend a little more time on the polishing stone than you may be used to, but you will get a fantastically polished edge when you are done. Another good note for Arkansas stones is that they don't wear anywhere near as fast as other synthetic stones. When using the JCKT-3, just dunk it in water and let the stone soak for a bit then pull out and use either side. Make sure to keep water on whatever surface you are using at the time. To clean go ahead and dunk it again and rub your finger along the stone to help break the metal fragments while the stone is saturated with water. If the Arkansas stone gets loaded down, just follow standard Ark cleaning processes.
As far as storage goes, it being credit card sized really gives you a lot of options. In fact, you can just go to amazon or ebay and type "Credit Card Holder" to find a plethora of options.
So that's it! I call it the JCKT-3 but you may call it whatever you like. Any thoughts and opinions would be more than welcome!
Here is the idea:
Dia-sharp
Arkansas Stones
Soft: Medium
Hard: Very Fine
Black: Ultra Fine
Fine Diamond Side
Hard Arkansas Side
After the cut
Same as above
Size comparison
