DLC, Boron Nitride, and Titanium Nitride finishes are so thin that they don't have much bearing on the "flatness" of the finish. They take on the appearance of the surface before coating. If you coat a polished blade it will be glossy, if you coat a bead blasted blade, it will be matte, and if you coat a coarse sandblasted blade, it'll be a very flat and rough finish. I'm a bit surprised that the DLC coated stuff isn't more rust resistant, I know titanium nitride doesn't do much unless the steel has additional anti-corrosive layers of plating, but IIRC the DLC surface was supposed to be non-porous enough that it wouldn't allow water vapor to creep through the coating and cause rust.
