I don't know how you drilled the holes, I tried solid carbide bits and broke them. Had a machinist try and he broke them. A HSS drill bit won't even make a mark you can feel with your fingernail! I figured the only way was grind them, so gave up.
As for SiC stones, the Norton jb8 oilstone is excellent for $20usd. If you want waterstone, someone else will have to chime in.
M2 and CPM-M4 is very good, but can't seem to take very high hardness with conventional heat treats and hold up. These 5-10% cobalt HS steels are on a different level, especially with the industrial heat treat for cutting other steels. I've been waiting 25 years for someone to offer folders in this stuff, and thought HAP40 was going to be it, and probably could be, but so far falls short due to heat treat... then Maxamet comes along, thanks Spyderco.
NJBillK
Never used DMT, but I have a 30 year old eze-lap 1x4 that is wore almost shiny in the middle from hundreds of hours of heavy pressure and is very smooth, but still cuts.
