- Oct 22, 2012
Hey guys,I'm thinking of buying a DMT aligner and I notice that the lowest angle for the 1" blade width (which pretty much all of my knives fall around) comes out to 32 degrees inclusive. This is fine in my books for many knives, but I'm a fan of higher Rc steels, and would prefer edges al lower angles down to 20 degrees inclusive or close to it.
So, I notice that the lowest angle for the 4" blade width is 12 degrees per side, which is much more suitable for the higher hardness steels I have like M4. So my question is: What do you guys recommend to make a sort of extension for the DMT clamp or to affix to my knives that would hold them securely 3 inches or so away from the clamp, thus making use of the lower angles that come with it? I thought very thin pieces of plastic or metal (the maximum blade thickness for the clamp is .25"), but I worry that the materials at the appropriate thickness wouldn't be stiff enough. Or, if you guys don't think it's worth it to try, can you guys recommend a system that could reprofile and sharpen as well or better than the DMT with the ability to take edges down to around 10dps? I've looked at the Lansky, but it seems to have similar settings. I'm open to all suggestions, but I'm on a budget right now and would like to keep costs down.
P.S.) I've been trying to freehand for months, and I'm really looking for a system that's reliable and easy to use. It just hasn't taken.
